30-03-13, 01:57 PM
Went out on the bike today it was first time in month after breaking ribs, anyways the right hand indicator flashes fast the left normal speed and when the hazards are on normal speed I'm baffled any ideas ?
Indicator flash speed problem
30-03-13, 01:57 PM
30-03-13, 02:09 PM
Blown indicator bulb is the normal sign.
30-03-13, 02:18 PM
They are all still working :\
30-03-13, 02:53 PM
Working with little info here but have you replaced a bulb with a led bulb at any Pont?
30-03-13, 03:00 PM
Nope nothing like that the only thing I can think of is replacement bulb isn't same wattage ? I only tested on hazard so that may be why I didn't detect it
30-03-13, 03:02 PM
If they all flash at the normal rate when on hazard & the same rate when on left turn it means it can only be the contacts in the switch.
Try some contact cleaner or WD40 & spray liberally into the switch & be aggressive with the switch action. It should clear up.
30-03-13, 03:52 PM
Ill give that a try thanks
« Next Oldest | Next Newest »
