Exup cable lubing
What's the best way to lube the cables, I don't want to remove them from the servo as it seems to be a tad awkward. I see on Pat's page that it might be best to lube from the bottom?
Any ideas??
Mickey
[Image: 73337.png]
disconnect from the exup valve at the bottom, find the adjusters up by the rhs of the airbox, undo completely. fill with gt85 and a cable oiler so you only have to go across gravity to the servo. re-assemble and adjust cables. 1/2 hr max
You made that sound so easy, will I be cursing you later though?
Mickeyboy
[Image: 73337.png]
Not as much as we are cursing you given your signature  :b :b :b !!
