dont always start
hi ya for some reson my bike wont always start on the
button do you guys have any idea where to look
as i'v looked at the button but see why it wont ? .
Do you mean when you press the starter button the starter doesn't always turn the engine over or the engine does turn over but it doesn't fire?
when pressed button nothing happans, (the starter )
Check that your battery is connected good and tight first anyway and that it's properly charged. When you press the button does the oil light and low fuel light come on or does nothing happen? If those lights come on then the switch must be working. So the next most likely thing to act up is probably the kill switch on the handlebars. Take that off and check and clean it. If that's working the next handiest thing to test would be the starter relay, if that's working you'll have to check all of the other cut off switches and connections.
Good advice above ^ Do you hear any noise or a click etc when pressing the button?
