Swapping the exhaust how to??
Does anybody know how to change the exhaust? What process is required etc etc.
I am about to buy a end can for the bike (DanMoto) and wanted to know how I would change it.
For starters, make sure your link pipe is the same diameter hole as the new end can and the downpipes, they're not all the same, as i found out when fitting mine!
If it's the same then it's just a jubilee clip to undo and a hanging bolt, hence the term "slip on".
Some people use a high temp silicone sealant to seal the join, i would personally avoid Gun Gum though as it's horribly messy to use and dries solid, so if you want to take it off later on you need to chip it all off.
There is a jubilee clip to undo just at the end of the link pip where it joins the downpipes (just behind the right riders foot pegs) then there is the hanger to remove from the rear pillion footrest, then it's a "simpl"e case of pull it off the downpipes and "slip on" the new one onto the downpipes and do up the jubilee clip to clamp the seal so it doesn't leak.
[Image: 208008.png]
(06-02-13, 12:23 AM)xlewisbdx link Wrote: Does anybody know how to change the exhaust? What process is required etc etc.
Download the Haynes Manual in the download section. Go to chapter 4 and section 13. It gives you the procedure with photos. Self explanatory.
"Should" be that simple, a lot of people buy downpipes before the end can, but my aftermarket downpipes are a different diameter to originals (plus i don't know what make they are either for reference?).
And seeing most end cans are measured and advertised to fit original downpipes then you can have a problem like i did where the link pipe was about 5mm difference in size!
That's when a bit of improvisation kicks in!
Thanks for the advice guys.
What comes with the exhaust is:
link pipe
hanging strap
bolt with lock nut
Does anybody know about the legalities of it?
It's all about problem solving when you come up against things like that and usually it's the simple solution that's the best. have a look at the haynes manual and you'll be fine. only way to learn is to get stuck into it. there's always a solution to any problem... sometimes they can be expensive solutions but we all learn from experience and most experience comes from having to solve a problem or two.  Big Grin
as for the legalities. it'll say if it's road legal or not somewhere on the advert. My blueflame exhaust comes with a removable baffle. If I leave it in then it's legal and if the baffle is out then it's illegal. simple  Wink  We all know which sounds the best but we also know that it's not strictly legal. having said that we are bikers and legal isn't always the side we stand on  :eek
[Image: 208008.png]
(06-02-13, 01:02 AM)Chris link Wrote: we are bikers and legal isn't always the side we stand on  :eek
Except for when the MOT comes round Wink
As far as exhaust go then yes, the MOT can be the killer so Baffles are in for that for sure  Smile
Although, the eu stamp is on the actual exhaust and not the baffle so you could argue the point that it's got the stamp so it's ok. This is not a good idea and the best thing to do is to keep the baffle in. So I do... most of the time. haha
[Image: 208008.png]
(06-02-13, 01:04 AM)xlewisbdx link Wrote: [quote author=Chris link=topic=6180.msg56104#msg56104 date=1360108959]we are bikers and legal isn't always the side we stand on  :eek
That's another issue altogether, depends on your examiner?
Some want to see BSAU markings or the original exhaust, others don't give a monkeys!
The police like to see a baffle in place, it's an easy thing to spot for them.
(06-02-13, 01:08 AM)darrsi link Wrote: [quote author=xlewisbdx link=topic=6180.msg56105#msg56105 date=1360109084]
Some police are fine and others aren't. Best to be on the safe side  Smile
[Image: 208008.png]
(06-02-13, 01:08 AM)Chris link Wrote: As far as exhaust go then yes, the MOT can be the killer so Baffles are in for that for sure  Smile
Most of the time being the one day a year it's needed  :lol
(06-02-13, 01:08 AM)darrsi link Wrote: The police like to see a baffle in place, it's an easy thing to spot for them.
I have a Delkevic 350mm at the moment without the baffle in. I've not been pulled over yet  Wink
My last exhaust was a Quill straight through race can, no markings and didn't have a baffle fitted at all, and used to fly through MOT's.
The SP Engineering can i have now has BSAU markings, a baffle, and at the first MOT i got an advisory for noise!!
I then pointed out the legal markings but he'd printed the MOT already so i had a year with an advisory notice on which the police could see on their system if they did an ANPR check on the bike!
(06-02-13, 01:17 AM)xlewisbdx link Wrote: [quote author=darrsi link=topic=6180.msg56107#msg56107 date=1360109318]The police like to see a baffle in place, it's an easy thing to spot for them.
Famous last words.........
that'll be a ticket tomorrow then! hahaha.
My excuse to my MOT guy was that it's a sports bike it's supposed to be loud, and even with the baffle in the blueflame is wicked, he agreed and through it sailed... Back brake got an advisory though!!! cleaned out, new hel brake line and new fluid, so we'll see how it goes throught the next one!
[Image: 208008.png]
(06-02-13, 01:18 AM)darrsi link Wrote: [quote author=xlewisbdx link=topic=6180.msg56110#msg56110 date=1360109839]
More than likely, especially if I have a DanMoto on...
Hmm, friend of mine had a dan moto on his hornet.. wasn't that much louder than stock to be honest...
[Image: 208008.png]
(06-02-13, 01:40 AM)Chris link Wrote: Hmm, friend of mine had a dan moto on his hornet.. wasn't that much louder than stock to be honest...
really? They sound super loud on videos. To be honest I want an under tray before a exhaust.
(06-02-13, 01:44 AM)xlewisbdx link Wrote: [quote author=Chris link=topic=6180.msg56116#msg56116 date=1360111215]
Video's can be decieving  Wink
What other mods has your bike got?
[Image: 208008.png]
