I have to get a new rear brake disk. I usually go for Yamaha parts but the OEM disk is £152 plus postage. Bit of a rip off so I'm looking at either an ebc pro-lite for £68.24 plus postage http://www.demon-tweeks.co.uk/motorcycle...rear-rotor
It's just worn out. Lots of deep ridges so time for a new one. Don't think I'd risk a second hand one unless I could visually check it before buying it.
@dude i've just checked, and i put a rear Pro-Lite on in Nov.11, BUT i've been using sintered Galfer pads as well that work very well but have pretty much eaten the disc.
That's not saying a softer pad, especially EBC, wouldn't last much much longer.
I must add, remember i had big issues with my front brakes that have not long been sorted, plus i ride in traffic a lot, so it all adds up to virtual rear disc abuse!!
Ok cheers darrsi. I'm in traffic the whole time too so I'm heavy enough on the rear brake. Doesn't seem like your Pro-lite disc lasted that long then, only about 2 years? Might try the brembo one and see how that lasts.
(30-01-13, 11:24 PM)darrsi link Wrote: @dude i've just checked, and i put a rear Pro-Lite on in Nov.11, BUT i've been using sintered Galfer pads as well that work very well but have pretty much eaten the disc.
I've had a few mechanics here warning me against using sintered pads on the rear. One guy is a well know competitive rider here who rides against the likes of Adrian Archibald and owns his own workshop.
@ Dude
I have that EBC disc on the back with standard EBC pads. Threw the same combo on my Bandit 1200 as well.[size=78%]No problems to report so far.[/size]
(31-01-13, 12:35 AM)packie link Wrote: [quote author=darrsi link=topic=6080.msg54779#msg54779 date=1359584686]
@ Dude
Would you know what sort of mileage or time you've got out of the ebc disc packie?
Go for the Pro-Lite, they're cheap enough not to worry about, and you can be the next reviewer!
I'm a bad example, but i'm telling it as it is.
The Galfers on the the front are quite good, but i reckon i'll try SBS next time.
As for the rear, they've been shit hot, but at a price.
You just can't win sometimes......
(31-01-13, 12:42 AM)His Dudeness link Wrote: Would you know what sort of mileage or time you've got out of the ebc disc packie?
Both are only fairly new on the bike but I expect good mileage and a good few years from both. I would expect them to be in there or there abouts with the originals for wear and tear.
The trick is to keep the sintered pads away from them. No need for them at all. Braid your hose first and fit the standard pads. They have good bite and will be more than up to the task. I'm surprised Darrsi only got a year. He must have been very aggressive along with his sintered pads plus other forces were in play I suspect. My standard rear that came off the Bandit 1200 was still in the spec limit and I had 40K miles up on that in 10 years and that is a buget bike with budget parts. I expect at least 40k too with the EBC but with a shorter lifespan (probably 4 years x 10K miles) as I use the Fazer daily.
I wonder was there a period on Darrsi's bike that maybe his back brake was iffy and slightly siezed and in contact his disc unaware. I have never heard of someone going through a disc in a year unless some abnormal forces were at play. I was driving around town for the best part of a day in low gears with and didn't notice that my back brake was iffy and in contact with the disc. It's only later that I got out on the open road when I hand to wind it on a bit that the bike was being noticeably held back. Junked the caliper in the end for an FZ1000 baby.
@packie, my rear caliper's absolutely fine, but i had major juddering problems on the front for ages that totally baffled me so i had a tendency to use the rear way more than i should of.
Combine my weight and the bike's, and sintered pads dragging on the discs trying to stop and you end up with a quickly worn disc.
It's no big surprise at all, and there's no hidden problems that i don't know about.
It's still working fine now, but it won't be long before i'll be looking for a new one, and i'll be using softer pads next time.
The juddering at the front turned out to be a faulty braided brake line.
31-01-13, 10:30 AM (This post was last modified: 31-01-13, 10:46 AM by kebab19.)
There are loads of other Yamahas that used the exact same disc as rear brakes; I guess it depends on whether you want to take a risk buying a 2nd hand item. Is it 245mm diameter?
(31-01-13, 09:58 AM)darrsi link Wrote: @packie, my rear caliper's absolutely fine, but i had major juddering problems on the front for ages that totally baffled me so i had a tendency to use the rear way more than i should of.
@Darrsi....The "hidden problem" was only an after thought.
The main thing that I was trying to point out to Dude was that your back brake wasn't been ridden in a normal riding condition by you which you did point out to the Dude and which he should take more heed to.
The Dude needs to think about this....you were using the single back disc with a single caliper to do basically the same amount of the work of twin front discs and two excellent front calipers. If your back brake was getting used more and harder than the front, then basically you are swapping the function of the brakes around. This is abnormal so you got abnormal wear. I have no doubt that you would have done the same to the Brembo. Sintered read pads are a no-no too as they increased the demise of your disc as well. I would suspect also that maybe the rear disc might not be made of the same strength steel as the fronts are, which could also have attributed to your rear's demise. But this is only speculation on my behalf.
Ridden under normal conditions I would expect at least 40k +. How soon you get to 40K is how ofter you ride your bike of course. If you clock up 10k a year which is quite a lot (200 miles a week), you will get about 4 years of wear. As I said earlier, I have 40K up on my Bandit 1200 and that is a way heavier bike than the Fazer and I'm 17st on top of it and use a top box with stuff in it everywhere I go. I have done about 20K of that mileage in touring the continent with a passenger and full luggage (see below) so it has seen it's fair share of usage. But the usage wasn't abnormal. The main power of my brakes came from the front and not the rear. The rear disc have not even wore under the spec yet at 40k and still have a bit of meat on it.
(31-01-13, 11:15 AM)darrsi link Wrote: I've got the same Galfer pads on the front, with wavy Kagizume discs, and they've barely scratched them, and work very well too.
I had a set of Chinese Front Discs on a Bandit 600 with Ferrodo Sintered pads for over 2 1/2 years. Same feedback here....did the job very well and was about half the price of EBC's. Probably should have done the same this time around but I had a few quid burning a holein my pocket! :lol
But it just goes to show you how much of a load that is being put on a single rear disc with one caliper if you suddenly transfer more of your braking from the front that has two discs and two calipers regarless of what type pads you use.
Also, I'm no engineer, but I feel that when you use mostly a back brake, all the weight is in front of the brake (engine, passenger, and 75% of the bike ect) and it is trying to haul everything back (if you know what I mean), and I think that is a lot harder than the twin discs working in front of everything.
(31-01-13, 03:06 AM)gordon link Wrote: hi his dudeness i,v got a new rear disc here cost me £50 if you are still looking for one i,m in manchester
Hi gordon. What brand is you disc?
(31-01-13, 10:30 AM)kebab19 link Wrote: There are loads of other Yamahas that used the exact same disc as rear brakes; I guess it depends on whether you want to take a risk buying a 2nd hand item. Is it 245mm diameter?
According to their codes, potential matches appear to be:
XJR400
FZ600
FZR600 89-93
FZR600R 94-95
SRX600
XJ600 Diversion 92-98
YZF600 Thundercat
YZF750SP 93-97
TDM850 91-99
TRX850
TDM900
YZF1000 T'Ace
YZF-R1 98-02
Thanks kebab. I'll see if I can get part numbers for those bikes. I wonder could the hole pattern for the bolts be different even if the discs are the same size
