29-01-13, 02:45 PM
Hi all, I have just noticed my clutch lever is slightly catching my pass flash switch when you pull it in. not enough to make me flash while changing gear but it is visibly rubbing a flat edge to the switch.
The bike was purchased with a set of renthal bars but in truth I cannot see how the standard bars would make any difference to the lever position.
Does anyone else suffer this problem?
I am wondering if it possibly has a pattern lever or something not being exactly the right shape. It is however tempting me with getting some CNC levers to see if his improves it at all. :lol
Any suggestions welcomed. thanks
Lord,
Grant me the WD-40 to move those things that are stuck, the Duck tape to fasten those things that are loose, And the wisdom to know the difference.
Amen
Amen
