27-01-13, 10:12 PM
i can't believe that this is the third winter that i've owned my fazer! so this is the third time that i've stripped and cleaned and lubricated the exup valve... this year however the lower cable (at the valve end) is too loose. having read haynes and pat's page on adjustments i found that where i was expecting my cable adjustment nuts there's just plastic sheathing type covers. i can't seem to slide them away easily enough so 2 questions:
are these normally fitted?
should i simply cut them away?
is it clean enough?
