rear disc. rose joint. stand.
Half successful few hours. Spare rear disc fitted but worse than one that was on it. Managed to true it up to 3 thou on the DTI but don't know how it feels yet. Don't hold out much hope tho so new disc needed so it can be used at low speed. The mating diameter is also 3 thou out so maybe the mounting face is slightly out but hey. Fitted new rose joints on gear change but lever pivot is worn so its a bit sloppy. Fitted modified side stand to accommodate for jacked rear so she sits on the stand more upright. Need to fit additional brake light and 2 spots at the front.
Why are you fitting a brake light to the front?  :rollin :rollin :rollin
(11-01-13, 11:16 PM)unfazed link Wrote: Why are you fitting a brake light to the front?  :rollin :rollin :rollin
to show the cars in front I am braking of course. Der
