Year 2000 Yamaha Fazer 600 for sale. Generally decent condition, fork bottoms a bit tatty, mechanically brilliant. Located in Buckingham. Approximately 26,000 miles. 9,000 of which have been covered by myself over the last year and a half. In that time I have;
Changed the oil and filter 3 times.
Fitted a K&N air filter and NGK iridium spark plugs.
Balanced the carbs twice and reset the Throttle Position Sensor.
Fitted Goldspot calipers on the front as the standard bluespots were looking tired.
Zx6r front master cylinder with EBC HH pads and braided hoses all round.
Fazer 1000 bluespot rear caliper (the standard 600 one always seizes without fail)
3.5" front wheel allowing 120 rather than the standard 110 size tyres to be fitted, giving a much larger choice of rubber
New this year Stainless Motad Venom headers (the standard 600 ones always Rot without fail)
New rear Michelin Pilot Power, the front is still good with about 3mm left in the middle and a little more on the edges.
New head and rear wheel bearings along with seals.
New chain and sprockets fitted this year along with the updated front sprocket nut (the standard one isn't man enough and usually ends up lunching the gearbox output shaft if not replaced)
Scottoiler so the new chain and sprockets will last for ages with minimal maintenance
Taxed till the end of November, and test till May next year.
Looking for £1300 ono
If I get the asking price I will also include the standard bars complete with heated grips ready to plug in for the nasty weather and
the standard footrests.
Many other bits I'd be willing to part with for a little extra:
Seat cowl
Nitron race shock (choice of springs!)
K-tech linear 0.85kg/mm fork springs
Spare fairing
Standard 3" front wheel with 110 Pilot Power
![[Image: DSCN1342.jpg]](http://i909.photobucket.com/albums/ac296/thomsillycb/DSCN1342.jpg)
![[Image: DSCN1336.jpg]](http://i909.photobucket.com/albums/ac296/thomsillycb/DSCN1336.jpg)
![[Image: P1000072.jpg]](http://i909.photobucket.com/albums/ac296/thomsillycb/P1000072.jpg)
![[Image: P1000073.jpg]](http://i909.photobucket.com/albums/ac296/thomsillycb/P1000073.jpg)
![[Image: P1000075.jpg]](http://i909.photobucket.com/albums/ac296/thomsillycb/P1000075.jpg)
Seat cowl
Spare fairing
