Best brake bleeding method?
Just fitted new brake lines, bleeding them just seemed to take too long. :'(
I reverse bled them with a syringe and some clear tubing attached to the brake nipple and forced the fluid up to the master cylinder.
This helps get some fluid and pressure into the lines, but its a little messy and you still have to do the conventional pump the lever chore.
I see u can get a manual hand vacuum pump which pulls the fluid and air out of the nipple. There is also the air compressor version which seems even easier for anyone with a compressor.
Anybody use any of these for their bike and car, or any recommendations?
personally i would not use anything to do with a compressor ?...you just might end up blowing the seals out both master cyl and brake pistons!!!!!!!!! :eek
I've heard of kits you can get which act as a one-way valve at the bleed nipple - means you just undo it and stick this kit on so that the fluid is allowed out but no air can return. Makes life easier then to just pump the brake until the fluid runs through. Granted, I didn't find it terribly hard with the bike, but it would have been useful for my cage.
One other thing though, I found I had to go over all the joints for the banjos and bleed those as well - so undo the banjo a bit, pump brake (down or in depending on rear / front), tighten the banjo and then release. Basically, exactly the same as you would for the bleed nipple but do every joint. I had several air locks in the front at first when I did mine and this is what solved it.
Speed bleeders (also available by other names)
It's a bleed nipple that has a sprung valve inside it.  Just open the bleed nipple a 1/4 turn and pump the brake.  The valve allows the fluid/air out, but closes again to stop is sucking the air back in again.
Got these on the car and makes bleeding the brakes and incredibly easy, one man job.
Not sure what size the bleeders are on my calipers yet, but I will be finding out and getting myself a set in the future.
[Image: 138790.png]
I bought a speed bleeder for the bike and it is pretty shit. the tubing is a crap size, too short, too inflexible and you still end up with brake fluid everywhere...
I have this lovely task to do soon myself, but wonder if you can use a syringe to suck fluid out of the system in conjunction with one of these speed bleeders?
I need to source some more longer and more flexible tube so that the valve is further away from the bike, it might work OK then. Where is a good place to get clear tubing?
you can get clear tubing from b and q in various sizes(and you buy per meter i think) you can also get tubing from car shops(for windscreen washer) or pet shop (for fish tank air line)
i went to the expense of a hand vacuum pump and didn't get on with it at all - it may take longer but i prefer to 'faff' around with the conventional "pump the lever chore".
Someone sent me a postcard picture of the earth. On the back it said, "Wish you were here."
Steven Wright
(13-09-12, 09:44 PM)CRH link Wrote: personally i would not use anything to do with a compressor ?...you just might end up blowing the seals out both master cyl and brake pistons!!!!!!!!! :eek
Surely the pressure generated when you squeeze the lever hard is going to be way more than what a compressor can manage?
(14-09-12, 01:40 PM)JayB link Wrote: I bought a speed bleeder for the bike and it is pretty shit. the tubing is a crap size, too short, too inflexible and you still end up with brake fluid everywhere...
That must be something different to what I am talking about.  The ones I have don't have any tubing.
The ones I am talking about just replace the bleed nipple, you still need something to bleed it into (tube + jam jar will do)
http://www.speedbleeder.com/
[Image: 138790.png]
The final thing I always do is after bleeding the brakes, pull the front lever in and tie it firmly leaving it over night. Release it in the morning and give it a couple of pumps. It just brings the last few tiny air bubbles in the line up to the master cylinder and sharpens up the front brake.
Live life, Love life.
ive been using "gunsons easy bleed" for years with no problems......try the reverse bleed with a clean pump action oil can...both work well  Big Grin
(14-09-12, 09:12 PM)red98 link Wrote: ive been using "gunsons easy bleed" for years with no problems......try the reverse bleed with a clean pump action shot gun...both work well  Big Grin
does that really work Red ? :lol
I got about 3 metres worth for £2 or something stupid from a local auto factors - even somewhere like Motaman should carry something suitable I would have thought?
(14-09-12, 10:09 PM)ade the blade link Wrote: [quote author=red98 link=topic=4604.msg39150#msg39150 date=1347653552]
yes its very good  Big Grin [size=78%]......use this method when iam having trouble ,never failed me [/size] Big Grin [size=78%]....if you think about it,bleeding brakes the normal way your trying to push air down and it wants to go up [/size] :eek [size=78%]......i bought a new pump action oil can just for this job great on cages when you cant reach the nipple and pedal at the same time and one man operation [/size] Wink
if that fails use the gun  :rolleyes [size=78%]    [/size]
