13-09-12, 02:23 PM
Here's a great idea I've just seen mentioned on another forum.
If you want to change your oil, rather than faffing around with trying to unscrew sump plugs and then getting oil all over your fingers etc, these people have come up with a replacement valve that allows you to drain into a container (via a hose if you want) without removing a plug.
You just lift a lever, rotate the valve and you're sorted. You can even just drain part of the oil if you've over-filled it, rather than having to drain the whole engine and start again.
For £20 it looks like a really helpful little gizmo.
They don't list one specifically for Fazers, but there's an enquiries link you can send details to and if enough people ask, I'm sure they'll be adding it to the list!
