21-08-12, 08:49 PM
Just tried searching the forum for a solution but no luck, so here goes....
Been sorting this bike out today and have a couple of problems. Namely the rev counter and the other is the fuel gauge.
So firstly it idles correctly, no TPS error that I can see. However the needle sometimes when being reved gets stuck at 5K rpm! Sometimes it happens on the way up sometimes on the way down. I thought it might be the TPS setting so checked that and adjusted it (but it was reading correctly anyway!). I think it maybe a loose connector but why then does it rev past 5k and revs fine before 5k? I've also checked and syncronized the carbs today so they are working ok...hasn't stopped the sticking needle!
Additionally the problem of the fuel gauge isn't working (-related?) All other dash lights/fuel lights/speedo working fine. I have taken the float out of the tank and that is freely moving and the connectors are fine that end -it was 'half' working when I bought (aka reading in the area but not accurate) it but it was stood for some time before I filled it up. Now it just reads beyond full all the time, regardless of actul level (began doin this before I took the float out).
Any help/suggestions appreciated.
Cheers BozBoz
Cheers BozBoz
