just come back from a long road trip.1400 miles in five days,and i now have a rattle on the bike.....fine in netural put it in gear with clutch in and still ok ,let clutch out and start to move and the rattle starts,it sounds like something is loose as not in time with the speed of the engine......not had time to look yet but was thinking loose front sprocket or maybe cclutch problem ?...................is there and common faults with the thou i should check first
Look underneath, might be a refugee attatched :lol
I know its only the internet but they are real people ! ain't they?
manuel its faulty lol lol lol
Chain slack?
My own chain needs adjusting so seldom that I sometimes go for quite long distances before I get round to checking the slack -and more often than not it doesn't need adjusting even then. But, it usually catches me out at the end of a long tour and that's when it starts to make a noise -usually when pulling away and the load twangs it against the swing arm.
(05-08-12, 12:49 PM)Phil TK link Wrote: Chain slack?
thats what i thought it was so pulled over at a yam dealer somewhere in south west wales to have a look,bought some chain lube and checked the chain,have got a slight tight spot but not enough to cause the rattle :\
scrap it!!!!!!!!!!!!!!!!.....and put old faithfull bk on road???  .....you know it makes sense? :rolleyes .......
oh!...by the way?...could it be the clutch pressure plt bearing on way out?? :rolleyes .......
yoohoo !!..............sorry, i`ll get me coat :lol
(05-08-12, 02:20 PM)CRH link Wrote: scrap it!!!!!!!!!!!!!!!!.....and put old faithfull bk on road??? .....you know it makes sense? :rolleyes .......
hi clive my old matey..hope you are well.............ah yes my good old 600....going to see if i can get it mot`ed tommorow as i have another week off....my last post saw me have a new rear tyre fitted and i dont think theres anything else wrong with it...never failer an mot in ten years of ownership...........how you doing with your thou ?
(05-08-12, 03:31 PM)ade the blade link Wrote: yoohoo !!..............sorry, i`ll get me coat :lol
hi ade , how you doing......was in your neck of the woods last week on a mini tour of this great isle
had it running!!.....seems to rattle a bit?....no where near as quiet ass the 6.. :rolleyes ......still need a few bits yet?...not got the funds at mo to do owt else?....have you not had chance to look at your 6 yet then??
(05-08-12, 02:23 PM)CRH link Wrote: oh!...by the way?...could it be the clutch pressure plt bearing on way out?? :rolleyes .......
going to take a closer look at chain and sprockets tommorow,not looked at front sprocket yet so will remove cover and have a good poke around and no doubt a good clean while iam in there
(05-08-12, 03:40 PM)CRH link Wrote: had it running!!.....seems to rattle a bit?....no where near as quiet ass the 6.. :rolleyes ......still need a few bits yet?...not got the funds at mo to do owt else?....have you not had chance to look at your 6 yet then??
no not yet mate....just had a week on the thou...and very busy with work before that,week off now and time to spend in the garage........i get a lot more engine noise with the thou aswell,nothing worn i think its just the way they are
In addition to making sure all's well with the front sprocket, take a look at the exhaust rear mounting bracket while you're down that way. The weld holding it to the EXUP collector sometimes fails. Also, stones on the headers will give similar rattles.
Clutch pressure plate bearing failures aren't common.
(05-08-12, 04:39 PM)Falcon 269 link Wrote: In addition to making sure all's well with the front sprocket, take a look at the exhaust rear mounting bracket while you're down that way. The weld holding it to the EXUP collector sometimes fails. Also, stones on the headers will give similar rattles.
cheers falcon ....i`ll check the collector box out in the morning
I had exactly the same issue when I got my Fazer a few weeks ago. The noise was only evident when releasing the clutch and pulling away from a standstill. I put it on the centre-stand and found a tight spot in the chain. Thoroughly cleaned the chain with parrafin and then lubed it up and problem was gone.
QUENTIN TARANTINO - HALLOWED BE THY NAME!
(05-08-12, 11:46 PM)MadDogMcQ link Wrote: I had exactly the same issue when I got my Fazer a few weeks ago. The noise was only evident when releasing the clutch and pulling away from a standstill. I put it on the centre-stand and found a tight spot in the chain. Thoroughly cleaned the chain with parrafin and then lubed it up and problem was gone.
i think you could be right...there is a slight tight spot and the chain is gummed up a bit and ive not looked under the front sprocket cover yet...so a good clean , adjust and lube could sort it out
took the front sprocket cover off this morning....not a pretty sight....dont think thats been de-greased since new....chain needed a good clean aswell....build up of gunge was doing a good job wiping off any lube i was putting on the chain...also lots of gunge on the side stand pivot,a couple of times over the past week the stand has stuck half way up/down :rolleyes .....now all clean and running smoothly,i can see that the rattle was caused by the chain knocking against the plastic guard on the underside of the swingarm,it was hard to adjust the chain with all that gunge on there........ths shock looks like it could do with a good clean aswell,so seeing as iam on holiday this week iam going to strip the whole rear end and give it a good clean/inspect and reassemble........thanks MAD DOG MC Q......spot on
Pleased to help
(05-08-12, 03:36 PM)red98 link Wrote: [quote author=ade the blade link=topic=4106.msg33638#msg33638 date=1344177071]
should have let me know and called in for a brew and chinwag ya jelly :rolleyes . did you enjoy `the land of song`? lots of inbreeding down there and locals wearing wellies one size too big ( don`t ask ) ......oh go on then !! :rollin :rollin :rollin :rollin :rollin good to see perv...uh clive back on da scene....only kidding matey. how ya doing. v.busy this end with work too !! can`t complain tho
