headlight mod
hi guys /gals  i recently done a H I D conversion on my 2001 fazer  and just wondering is there anything that can be done to the other head light as it is a different shade of light if you no what i mean  :wall                                                        Thanks in advance    Swem  :thumbup
Hi
On the offside of my mk1 Fazer I've installed a direct replacement HID light with a solenoid dipping mechanism.
Link to earlier post :- http://foc-u.co.uk/index.php/topic,3734.0.html
ATB YFM
I had the same problem ... H4 Hid on the right (bright white) an the old H1 halogen on the left.
Solved it by buying an H1 HID from Singapore on Ebay but be warned - its probably not going to be a direct fit. There is a bulb-carrier on the left and you'll need to
figure out some way of holding the HID capsule in place so that its leads can connect to the ballast.
I used 15 layers of hi temp plastic from ready-meal oven containers. All cut to the same shape as the original bulb-holder but with a big hole in the middle. It was a bit fiddly but it works fine.
Hi
I used the back end of a 10 ML syringe body cut to the same length as the old bulb holder cut a slit down the one side to pass the wires.
https://dl.dropbox.com/u/70564722/H1.JPG
and used the grommet that was fitted to the H1 HID pushed into the modifed Fazer rubber light cover.
https://dl.dropbox.com/u/70564722/H1-%202.JPG
ATB YFM
hi mate where did u get offside bulb from ? cos i,v got two h1 singles in the box,
used one for nearside really want offside done but what hid bulb do i get ?
Hi
Its a H4 direct replacement with solenoid dipping.
https://dl.dropbox.com/u/70564722/H4.JPG
I'll looked up the info for you :-
From My Confirmation Email
Thanks for shopping with us today!
The following are the details of your order.
Order Number: XXXXX
Date Ordered: Tuesday 27 XXXX 2010
Detailed Invoice:
http://www.vvme.com
Products
1 x Digital Slim H4-3(9003) Bi-Xenon HID Kit (VVME-HKB93-DSL)  = £47.70
Color Temp. 4300K
1 x Single Beam HID Bulbs (VVME-HBBSB)  = £10.75
Bulb Type H1
Color Temp. 4300K
Sub-Total: £58.45
Express Shipping(3-10 Business Days)  (Express Shipping To GB (1 x 2.50kg)):
£24.06
Total: £82.51
I also brought the optional relay harness, it takes the switching load off the Fazer dipp switch.
The rear part of the bulb clears the forkleg on full lock OK.
ATB YFM
cheers bud , i,v found a place 4miles away what do the hid kits and bulbs popping down monday as i,m working all weekend. the nearside that is done well happy last night i could see where im going for a change
