Looking for reliable mechanic
Can anybody recommend a garage/spanner that would check/adjust my tappet clearances for me. I live in Welling/Kent and needs to be fairly local.
I've used both AC Bikes and Ride DMC, both in Dartford, and they were ok - there's also Bates in Dartford who have a pretty good rep but I've not used them for anything significant. Can't think of anyone closer to Welling tho - Metropolis in Greenwich? actually Metropolis in central London (Vauxhall) are pretty good at turning stuff around quickly if you commute? They're not cheap tho.
S
Someone sent me a postcard picture of the earth. On the back it said, "Wish you were here."
Steven Wright
Theres A2 Yamaha in Gravesend, used to be Brands Hatch Yamaha until they moved.
Are Garrozo still in Blackfen? I used to go there with me fizzy:lol
Thanks for your replies. I spoke to the guy in Gorozzo (now Sondel) and he said he didn't think it worth checking unless the bike was running rough??? Sounds like 3 hours work to check then another 2 hours to adjust if necessary. He didnt think I would notice any difference. I seem to have one tappet that is ticking for the first 20 seconds or so after first start up. Other than that it seems to be running OK. Now on 55k miles.
Tappets.  Oh, you dear old fashioned soul, you.  Wink
Noisy valve clearances aren't a worry, the cam-valve bucket gap is just a little larger than it should be.  Quiet valves are the ones to think more about.  Tight clearances can lead to burned valve seats.
That ticking on start up might be the cam chain adjuster.  Just a thought, mate. Smile
(03-07-12, 10:27 AM)steeeve66 link Wrote: I've used both AC Bikes and Ride DMC, both in Dartford, and they were ok - there's also Bates in Dartford who have a pretty good rep but I've not used them for anything significant. Can't think of anyone closer to Welling tho - Metropolis in Greenwich? actually Metropolis in central London (Vauxhall) are pretty good at turning stuff around quickly if you commute? They're not cheap tho.
S
I've heard more people say good things about Pol Pot than I have Metropolis!  :eek
(04-07-12, 09:30 AM)Pat link Wrote: [quote author=steeeve66 link=topic=3709.msg30160#msg30160 date=1341307633]
S
do they have a bad rep? i used Metropolis (Vauxhall) quite a bit when i lived in central London, also took my Direct Access through them many years ago, and never had a problem.
Others, clearly, have had a different experience.
The only time i've had a really terrible experience with a garage was with Laguna in Kent - dangerously terrible service.
Steven Wright
