Security for fz6
Me again,just wondering what sort of security you's use?Will a chain do it,I know sports bikes get stolen a lot, not sure about a Fazer!Also I need a back box,am I looking at £200 for rack and box?thanks.
Security: I use 2 Squire chains (I found one was a tad short) and tie the bike to a lamp-post or a similar solid object as far as possible. (Forget the model of chains, but I got them from Halfords, £140 each).
As for a back box, it depends how much space you need, I've got a Givi Monokey on mine, the rack + 45L box + fitting was £270 all up.
(03-07-12, 06:57 AM)bunahilga link Wrote: Me again,just wondering what sort of security you's use?Will a chain do it,I know sports bikes get stolen a lot, not sure about a Fazer!Also I need a back box,am I looking at £200 for rack and box?thanks.
I use a good quality disc lock and chain, plus it's got a Cyclelok alarm and it's been Datatagged which makes it difficult to strip for parts too Smile
You can get a top box that attaches to the pillion grab rails, but if you want panniers as well you need the Givi top box and pannier kit which is a) expensive and b) a PITA because you have to bolt it on to the underseat pipe mounts which involves taking apart half the back of the bike!
Going on with graham the givi rack is a pain to fit with the exhaust mounts need a dreamer to cut back a little of the fancy heat sheiks to get the given 2 :lol0mm bolts in I brought a topbox brand new from fleabay a 40L knock of a givi e360 and it's brill all for £20 hehe
Thanks lads, much appreciated.
I bought a brand new Givi rack from fleabay for£25 the only problem I had was the brackets would not wrap around my after market cans, and I had to make new ones up.
Out of interest, I have a spare set of the Givi Mounting Brackets and the bolts that go onto the underseat pipes on the 04-06 model FZ6-S (NB it's only the brackets, not the pannier mounts etc)
If anyone's interested, drop me a line and we can work out a price.
re top bo instead of getting a rack and box etc what about a set of soft panniers and or maybe a tankbag etc?i got very lucky at autojumble and got pair of oxford panniers for a tenner and got small tank bag for another tenner loads of space between them for carry all sorts at fraction of hard box and easy to remove if needed
(03-07-12, 01:31 PM)Grahamm link Wrote: You can get a top box that attaches to the pillion grab rails, but if you want panniers as well you need the Givi top box and pannier kit which is a) expensive and b) a PITA because you have to bolt it on to the underseat pipe mounts which involves taking apart half the back of the bike!
Interesting; I've been looking for this. Top-box would be handy but I don't want a permanent rack. Got any links?
(13-09-12, 06:43 PM)breadlord link Wrote: Interesting; I've been looking for this. Top-box would be handy but I don't want a permanent rack. Got any links?
Not off hand, but a bit of searching should find what you're looking for.
