30-06-12, 06:22 PM
I have only owned my Fazer a couple of months and it has rained for most of that time , so when I got up to a bright sunny day the plan was a bit of bike maintenance and then out for a good long ride in the hills - but alas not to be !
I have had a slight fuel leak which I assumed was something to do with overfilling the tank last time I fuelled up ( thought it was an overflow pipe thing.I lifted the tank to check to air filter and dry off the over flow only to find the bottom of the tank has been very badly repaired. After a bit of light sanding the bottom of the tank looked like a lump of Swiss cheese.
The tank was full of rust and quite frankly past repair - after a trawl on the net I have purchased a replacement tank - unfortunately a YELLOW one!
I am still on the look out for a black tank if anyone has on.
"Don't Die with Fun in the Bank!"
