21-06-12, 01:15 AM
on my way in to work,,, my fz6 would only change up to 2nd gear,, with a bit of coasting got int higher gears,, any ideas??
cant change gear!!
21-06-12, 01:15 AM
21-06-12, 01:18 AM
Clutch pushrod? Chain too tight?
Anatidaephobia: The fear that somewhere, somehow, a duck is watching you.
21-06-12, 06:31 AM
First thing to do is clean, lubricate and adjust your gear shift mechanism. Then check and adjust your clutch cable and check that the clutch is operating, if it selects 1st and 2nd gear and pulls away properly it should be ok.
Another thing that can break is the detent spring which makes if difficult to select gears, this is also easy to change, normally behind a plate close to the front sprocket. Have you checked out the link for Hot Poop near the top of the page? Good luck |
« Next Oldest | Next Newest »
