High Wind Noise - Would flip up screen help ?
i am getting a lot (and i mean lots) of wind noise at anything above 40mph
at the moment it looks like i have a "double bubble" type screen fitted.
if i were to replace this with a flip up type, would that help ?
thanks Smile
Tried ear plugs?
I get a lot of noise at 90+ but that might also be my cheapo helmet letting the side down..
i use ear plugs all the time (thanks for the suggestion though Big Grin)
fairly sure it's not my lid (Nolan N104) as i had the same problem with my old one.
would really like to get it sorted as it gives me a headache after a while.
chk out powerbronze products?....seem to think they do a flip"top screen that fits a fazer?...thats bt only thing that will cure it?
In my experience taller screens usually generate more wind noise. The MRA Vario can be useful for most people od differing height because it's vane angle is multi-adjustable.
Expensive piece of tho...
I get a bit of wind noise off my standard screen around 70-80 mph, so got a double bubble from Powerbronze thinking it would reduce it.  It made it far worse, I was getting wind noise from 40-50mph.  The standard screen causes the wind to buffet on my chest area but the double bubble screen raised it to my head making it alot noisier.  I put the standard back in and sent the double bubble back.  I wear ear plugs all the time it helps.
thanks for the replies
i'll see if i can get an original screen to try
