hi all, got fazer booked in for mot friday morning, so just gave it a final check over! ran it around my estate to bed new pads in etc! and noticed that my neutral light wont go out!!!! through non of the gears up or down box! stays on all the time!! any ideas??????
Cable trapped when the sprocket cover was last screwed down?
Don't think it would cause an MOT failure, but I'd tape over the light with black insulating tape or take the bulb out if you can't find the cause before the test. (Believing you're in neutral when you're actually in gear being more likely to cause an accident.)
cheers for that fazerider! not had the cover off myself? but ile whip it off now you said that and have a look!! (check out sprocket nut at same time ???)
I had this and traced it to corroded plug in the wiring box under the tank. Caused by water ingress due to fighter styling and single headlights allowing a route in.
Sorted by wire brush, wd40 and a plastic bag to cover the opening. Easy fix
well? had cover off and everything ok in there!! noticed (original) 9mm nut still in place!!! so? tiberius " ile take tank off like you suggest and have a look there!! amazin int it? a few wks ago booked me zafira in for mot never had any problems with it since i bought it 4yrs ago!! day before i take it?.....rear brake lights pack up!!!!! looks like this is going to be another bstd????????
ok!! had tank off, everything under there fine!! no corrosion anywhere? dont know if this has anything to do with it? but!..when engine running , clutch in , 1st gear engaged , flick sidestand down, light goes out.and engine cuts out!!! now should i now be able to pull clutch back in with side stand still down and engine start? if so it dont!!!
assuming that its not the actual neutral switch that is stuck closed. then unfortunately it is probably an earthing fault that could be almost any where within the loom.
if the faults in the loom it may be best to disconnect at each end and run a new wire down the outside of the loom,save upsetting the loom and less work
thanks for that red! i may well be doing what you suggest? its a bstd! hate anything electric! just peed off its 2days before mot? ive tried every ones suggestions! appart from the last from clayt" check if actual neutral switch is jammed? after that then see if i have a bad earth or fracture somewhere? just hope they dont pick it up on mot if i havnt sorted it by then?
If the side stand switch stops the engine then it sounds like it's working. Looking at the drawings there is a diode between the neutral light and switch, so if water or a damaged wire was earthing the lamp (therfore lit) between the lamp and the diode then the switch would work and stop the engine but the lamp would be always lit. Sadly can't explain why it went out when the engine stopped though. I'll keep looking so let us know if you get it sorted or if it sorts itself.
hi, andy! been in garage for 3hrs tonight, been through all wiring etc associated to the neutral switch couldnt find any bare/ trapped wiring that could be causing it! everything looks intact /clean etc. have noticed one thing though?? when the gear selector is in neutral " the neutral light is very bright!! when put in gear its dim!! so does that sound like a earth fault??? i havnt took out the neutral switch yet as ime not sure what seals it in? o ring or gasket?? by the way? the light doesnt go out when engine is stopped!! only when sidestand is put down!!! cheers clive.
from what you've just said there about it being on bright in actual neutral and then on dim in gear suggests a parallel path or a cross connection somewhere drawing some current throught the neutral light from some of the other circuitry, have you had a look on the back of the clocks? not sure what the wiring looks like on the back but if there are any terminal blocks or plug connectors it might be worth inspecting those. also it might aid the fault diagnosis if you look to see if any off your other light dim/brighten when you go in and out of neutral - could give you a clue as to where it's drawing current from.
I've been looking at the drawings some more and concluded the following about the neutral lamp.
1, The lamp has +12V with the main switch "ON"
2, The lamp illuminates when in neutral via a diode when the neutral switch connects the lamp to -12V (earth)
3, The neutral switch also when in neutral connects the ignitor unit to -12V and also the Starting circuit cut-off relay.
So if the engine starts without pulling the clutch then I would think the neutral switch is ok, BUT a slight earth fault caused by the dreaded water or damaged cable might cause the lamp to glow.
Also the manual states that the neutral switch is sealed with an "O" ring but shows that the connection can be removed without removing the switch.
You say that the neutral lamp goes out when the side stand is "Down" this could be due to a diode failure as looking at the drawings the neutral switch and the side stand switch both go to the starting circuit cut off relay via diodes to stop back feeding. As far as I can tell the diode unit is a small block under the tank below the coils but above the carbs.
I hope some of this helps as I'm just going on what's in the manual and I've not seen any of these parts first hand so to speak.
(17-05-12, 04:11 AM)Andy FZS link Wrote: I've been looking at the drawings some more and concluded the following about the neutral lamp.
Best of luck Andy
I have to agree with Andy about the diodes. it does appear your neutral switch is working correctly and the fact that with stand down the lamp goes out and when stand is up lamp is dim does indicate a parallel path, the diodes are there to block that path.
from what i can see the diodes are part of the "starting circuit cut off relay" item 31 on this drawing.
ok, thanks for that byker! ile chk that out later! and thanks to you again andy! going to spend the day on it today, and double check everything as i go along!! ile try and locate that diode and see if i can either get it tested or get another to try! thanks again clive.
thats brilliant clayt!! that will help no end? like ive said? going to spend the day on it!! ime sure with the help you lott are giving me, ile find the bstd !!! .....eventually !
