new carb rubbers
anyone now where i can get fzs fazer carb rubbers appart from ebay new or second hand thanks from kevin
you can get them from a yamaha dealer using the part number catalogue
ok thanks i ment to off said funds are  tight i can get them from M&p for £65.00 wasent sure if anyone new a cheaper place cheers
65 is probably the cheapest you'll get them new. they're fairly expensive. someone on here has a set though
(12-05-12, 05:04 PM)His Dudeness link Wrote: 65 is probably the cheapest you'll get them new. they're fairly expensive. someone on here has a set though
that should say someone on here might have a set
Are you sure they need replacing?
They may look split but the material is quite thick and the cracks take a very long time to get all the way through.
If yours really are leaking, try smearing some of black silicone sealant into the cracks as cheap alternative to replacement.
Yep! Good old silicone.Worked a treat on mine.Use on the outside!
i got set for my bike last year from ebay buy know 13 pound  or o.n.o i am tight ass as well i offe 10 for the set secondhand  but no cracks and he took it fecking 10 pound best thing i got off evilbay  Wink :rollin :rollin :rollin :rollin
bloody baragain m8 there 65 new
(14-05-12, 10:32 PM)reggae123 link Wrote: bloody baragain m8 there 65 new
i know if u can wait they do come up a lot i saw set went about 6 weeks ago for 20 pounds on ebay good luck Wink
the carb rubbers on my thou were cracked to hell,they looked bad and the bike has 70k miles on it,i managed to get a set off ebay in good condition but i had to pay £52 for mine,but not one of the rubbers had split all the way through
