Im having issues with my Frazer 1000, the battery has gone dead after recently trying to start it, bought a new battery, charged, and put this on the bike and it has now no functions that work, i.e no instrument lights, noise, nothing!
Can anyone shed any light on this matter, would be greatly appreciated.
Cheers rob :'(
I know you state the "new" battery is charged, but what voltage do you get if you put a test meter on it? What charger did you use - a couple of hours with a fast charger, or a trickle charger on all day?
Check all your conections again make sure they are tight and above all check ALL your fuse's.
i would place money on you blew a fuse
could u have put the battery in backwards?
you have turned the key haven't you?
kill switch?
Sidestand switch? immobiliser?
The Frying Scotsman
did you connect the wire that goes over the battery? also have you checked the fuses,one could have blown
