renthal bars
Hi i have a yamaha 1998 fazer , id like to change the standard handle bars for renthal bars. Does anyone know if this is an easy job, plus would i need to change anything else on bike? would they foul the fairing when turning etc. Long term i would like to change to a street fighter look, does anyone also know how u go about this , with getting parts etc
http://foc-u.co.uk/index.php?action=dlat...ttach=1516
is this the sort of thing ? complete with renthal bars. This was my partners bike i did for her. no more. very long story  :rollin
Yes , long term. Was gonna fit bars first.Bike looks good.
Heres my bike i streeted after a crash with a blind cage driver
Put renthal ultra low bars on much better than stock.
[Image: IMG20110818_006_edit.jpg]
from my cash the OEM bars are bent so ill be probably after some renthals will they still fit all the cables etc?
ultra lows didn't need anything doing to the cable routing
all i had to do was drill 2 holes for the switch gear pins
easy job
No need for that just file the locating pins down, the switch gear is solid absolutely no movement at all.
Thanks all , will have to order soon . Great look
Keno where did u get rest your mods, headlights and screen?
The headlamps,mini indicators and fork brackets came as a set for £100 from bandit mania but they dont sell them anymore.You can get the dominator headlamps on ebay.
http://www.ebay.co.uk/itm/Dominator-Twin..._917wt_932
The fork brackets,but not the same as mine.
http://www.ebay.co.uk/itm/Motorcycle-Caf..._828wt_698
The screen.
http://www.ebay.co.uk/itm/Streetfighter-...5558wt_808
The clock bracket i had to make myself from aluminium sheet as the original was destroyed in the crash..
Hope this helps you if you decide to street the bike "I was going to do this eventually even before the crash anyway"... Wink
Nice one will have to save a few pennies then im on it, thanks very much for the links
