07-05-12, 01:31 PM
Anybody know which size I need for an 01 fazer 600?
Thanks
Thanks
Oil filter wrench
07-05-12, 04:25 PM
hi, i think its a 69mm thats the metal hexagon type with the half inch drive center? ime sure if ime wrong someone on here will put me right??? cheers clive.
07-05-12, 04:41 PM
if like me you replace the whole filter (im not sure if its possible to just replace the inside)
you will need: a screw driver (pointier the better) and a hammer step 1: using the hammer hit the screw driver into the oil filter step 2: use the screwdriver to turn the oil filter and take it off the bike step 3: screw on new filter by hand should be able to get it tight enough using your hands mines never lost oil and i have always hand tightend the oil filter
07-05-12, 04:48 PM
or just get a chain type wrench. i used a leather belt to get one off once. worked fine :lol
(07-05-12, 04:41 PM)mike26 link Wrote: if like me you replace the whole filter (im not sure if its possible to just replace the inside)if you are going this route hit the rim of the filter where ir screws onto the oil cooler to turn it,i did it this way as my oil filter tool would not turn the filter and on the thou there is not a lot of space,a couple of taps and the filter turned with minimal damage to the old filter and no splillage and i did not have to hit it hard either
07-05-12, 07:46 PM
(07-05-12, 04:41 PM)mike26 link Wrote: if like me you replace the whole filter (im not sure if its possible to just replace the inside) this is all well and good, until you get to a filter thats been put on by a ham-fisted mechanic, and done up tighter than a gnats whatsit. then the screwdriver just rips the filter apart, and you've made yourself a world of pain. Use the tool on the end, or a chain whip. Its why the proper tools were invented. (07-05-12, 04:41 PM)mike26 link Wrote: step 3: screw on new filter by hand should be able to get it tight enough using your hands mines never lost oil and i have always hand tightend the oil filter absolutely, just wish the poxy hamfisted mechanics knew that !!
07-05-12, 07:59 PM
I bought a wrench from ebay when i started doing my own oil changes... but i only put them on hand tight and they always screw off with the hand again.. handy to have though!
07-05-12, 08:04 PM
i allways use the metal cap type tool that fits over the filter!! perfect fit and no chance of slipping off! like rich says? u mank it up and you then end up mankin ure hands uptryin to remove whats left! being where it is too! right be hind the pipes!! you can quite easily get the cap type on with a bit of jiggling? and your ratchet bar will squeeze between the pipes ! you then get to spin it off with no effort!! JOB DUN!!
07-05-12, 08:11 PM
[img width=100]https://s-external.ak.fbcdn.net/safe_image.php?d=AQB1Dzdu2fR1Vpuz&url=http%3A%2F%2Fi.ebayimg.com%2F00%2Fs%2FMzg2WDgwMA%3D%3D%2F%24%28KGrHqZ%2C%21iIE8LNufJV7BPPP%29%28bsyg%7E%7E60_1.JPG%3Fset_id%3D8800005007[/img] http://www.ebay.co.uk/itm/DRAPER-13771-O...5ae6291d4c about £5 you can get one of these. As someone who has focced up a filter with a screwdriver - don't -once ripped if its tight - other tools won't work anymore as a torn one just distorts when using a chain or a strap.
07-05-12, 09:14 PM
5 oil and filter changes later never used a wrench fitting yet :eek just an old cloth
07-05-12, 09:18 PM
Thanks for the replies.
Ordered one off Wemoto. I do my own oil and filter changes and hand tighten filter. Sometimes its still a bugger to get off because access isn't easy with the pipes. last change, I spent 15 minutes swearing and vowing I'd get a oil wrench filter before the next change. So I have. ![]()
08-05-12, 09:42 AM
I used to do the old screwdriver trick but got fed up with hot oil spewing everywhere..
Had the grippy filter pliers but even they didn't work best in a tight place. Now use the wrench that fits over the cap, just remember to fit it first behind the exhausts before warming the oil up! |
« Next Oldest | Next Newest »
