Can I ask the wisdom of you folks about 25mm jack up kits. I've heard they're good and improve the handling but could someone explain how they do this and if possible give a link for the right kit for a 2002 foxeye if recommended
		Jackup kit simply raises the back end from the swing arm, it improve handling in some cases as the bike turns in quicker
		easier way is to lower the front end a little bit.
has the same affect.
just be careful you don't lower it to much as the front end may clash with the upper fairing.
If I wanted to make a life-long career out of
working with the mentally retarded I would
have opened a Harley Davidson Dealership!
