Side Light / Brake Light
Quick question, should the front side lights come on with the brake lights?
Not normally, no.
Not ever!
no, no, no ,no ,no
Perhaps a poor earth on the rear light cluster and the brake light comes on by picking up an earth through the side lamp circuit causing the front lights to glow? Just a thought.
Have you had a blown bulb changed recently, if someone has fitted a single filament bulb to a twin filament holder the sides will get a live feed when the brake is applied, seen this on many cages. HTH.
That will be a NO then, cool, will start the investigation and first on the list is to check the rear bulb, thanks all.
