Just noticed the annotation F1. I'd have expected this to be a fuse, but then why would it burn up instaed of blow?
And I meant regulator, not rectifier. Doh!! (where has the Modify post button gone?)
It looks like a vitreous enamel resistor as to value sorry no idea
Its just a ride
Cut it out - there may be some colour underneath. If not, see if you can remove the burnt coating (may just be on top!) with some Jif/Cif/TCut/fine sandpaper to see the colours, or any other identifying marks.
Diode may be reverse-polarity protection - but it may also be simply acting as a fuse. Its not something I'd replace with wire however.
It may be burned, but it might still be semi-functional - it can happen.
If you have a magnifying glass, you may be able to make out any identifying characters (eg 1N XXXX).
Final point: although you've identified the burned out diode, it'd be a good idea to make sure you've identified any underlying faults to prevent the new one going the same way.
Looks like a fuse to me ... Problem is that a fuse is either "there" or "not there" and in order to blow like that (obviously hot!) it must have passed a LOT of current in the few milliseconds before it blew. Which means that its a symptom of something else.
Expect something horrid downstream of that fuse.
Have a close look at all other components on the board with a magnifying glass. You might find something simple to replace and THEN replace the fuse.
OR ... if someone had reveresed the polarity of the power supply, or plugged in the wrong one by mistake - that might happen with no other defects.
If it's drawn lots of current replace the regulator as well as that should be the limiting factor, a diode makes sense for polarity protection, check the datasheet for the regulator and you'll know the max current that the diode should have to deal with.
Maybe the mains adaptor has gone wrong and put unregulated voltage to it.
Thanks for all of the help guys. I think there is discolouration at the regulator, but to be honest it's a multi-layer PCB and I don't have the equipment/skills/inclination to fix it, so I think I'll just bin it.
Cheers,
Andy
Looked like the (remains) of a fuse to me - some of the on board ones look like a diode (and in some cheap kit they use a forward biased diode)
Bet you anything the regulator (3 legged thing next to it) is short.
