13-04-12, 11:19 PM
i took the air filter out and i found it was a bit dirty,and on the top of the filter was a date,
![[Image: IMG_0530.jpg]](http://i268.photobucket.com/albums/jj38/solorider_uk/IMG_0530.jpg)
you can just make out the date and it is july 2005,here is a pic of the inside of the filter
![[Image: IMG_0531.jpg]](http://i268.photobucket.com/albums/jj38/solorider_uk/IMG_0531.jpg)
all this is basic servicing,which looks to be neglected,the bike does have iridium plugs so someone did spend out once,i will get a new set and replace them but they do look ok.
for the air filter as i could not get one localy (my local yamaha dealer went bust (george whites) and the local bike shops could not get a price so i made an air filter,i just happened to have a vauxhall midi (i think) air filter which is a cylindrical shape,i cut it down and it fits nicely inside the air filter box,and it ha a slightly bigger filter coverage,and the cost was zero,here is a pic of the part i did not use
,yes i did clean it up before fitting,it will do till i can get around to fitting a k&n or similar filter.
i also have a working choke,which my bike does need on a cold morning,this morning my bike took a while before it ran properly because it was cold,i recycled some bicycle parts i had lying around,it cost me just £3 for an inner cable
![[Image: IMG_0533.jpg]](http://i268.photobucket.com/albums/jj38/solorider_uk/IMG_0533.jpg)
so i have managed to do things on a budget,my next job is to get some new clutch plates which wont be cheap
,yes i did clean it up before fitting,it will do till i can get around to fitting a k&n or similar filter.i also have a working choke,which my bike does need on a cold morning,this morning my bike took a while before it ran properly because it was cold,i recycled some bicycle parts i had lying around,it cost me just £3 for an inner cable
