Gen 1 shock measurements
Does anyone know, or could someone measure, the width across the top mount and the width inside the bottom mount fork of a Gen 1 OE rear shock please?
Ta
The gap between the blades is 30mm, the width of the top mount is 25mm but the bush is 35mm.
Just measured with a rule, I haven't a micrometer so best I can do.
beware the battery x member fouls most shock options hence the r6 fit's but i tried others before i found the r6 fits
Nice thanks fellas.
Luke I sent you a pm.........
