Hi,
On long runs not giving it plenty I can also get quite close to 55mpg, but once when I did a north to south of France run in one go at a little over the limit (!) it dropped to 45 that was averaging close to a ton though, so I think the gen1 is capable of serious mpg even if you do give it a bit. The most I have got on the trip before bottling it for a garage was 210 could only get 19 litres in it at the garage.........
220 miles from a tank before whilst bricking it trying to find a station. I pretty much always get about 55mpg though, really consistenly it seems regardless of how I ride (within reason)
I also much prefer an analogue gauge as you can actually see the petrol run down in real time. The digi ones start flashing at reserve but obviously you get no further idea. Obviously, you can check miles etc but it's not as good
04-04-12, 06:18 PM
(This post was last modified: 04-04-12, 06:26 PM by dazza.)
Hi all, I know I said I didn't want to turn this into a competition but I may have lied..... Have just done 228 miles to a single tank before the thought of the dreaded walk of shame became too much to bare. Pulled into a garage and brimmed the tank with 20.9 litres. Agood call I THINK. Have got to say towards the end it felt so light and flickable it felt like a different bike. You really must try this.
How far did you get after the fuel light started to glow? I can never seem to get more than about 18 litres in mine from what I consider pretty much empty, though my tank is dented and probably holds a litre or so less than it should :\ . Trip to work is 33 miles and I can do there and back twice and there again (165 miles for the numerically challenged) before I get twitchy and feel I have to refuel. I might just take a few litres in a can in a rucksack and see just how far I can go.
Interesting point pieEater, have wondered about dropping the forks through the yokes...any suggestions as to how much. I recently aquired a copy of july 06 Bike magazine where Master Mike (Falcon) tests the Fazer against the gen 2 and set my front and rear suspension to how he adjusted the test bike. As for a jack up kit I'm a bit of a short arse and already find myself tiptoeing on adverse camber stops, so not keen on making it higher. :\
