FZ1 fuelling issue.
Ive just fitted a Mivv Titanium gp end can and link pipe to my 2011 FZ1N. The throttle is still slightly snatchy when throttling from off to on. Somebody mentioned an electronic box gizmo (not power commander) that you can plug in which is supposed to reduce this. Any recommendations as to which one and where to get one from??  :rolleyes
[Image: 139938.png]
Are you thinking of Ivan's FCE (Fuel cutoff eliminator)?
This helps to eliminate the snatchyness associated with the FZ1
Aaah, yes that sounds like the bit I'm after. Can you recommend a good place to get one??
[Image: 139938.png]
Ummm....not sure really soz. My FZ-1 had already had the mod done when I bought it.
You could start here... http://www.ivansperformanceproducts.com/fce.htm
I'm sure someone will come along who's a little more helpful!
http://www.sgmotorsport.co.uk/  uk distributor
They are also on ebay http://www.ebay.co.uk/itm/Yamaha-FZ1-Faz...19cca52995
Thanks. Just ordered Ivans Fuel Cut Eliminator..... will post on verdict as soon as it arrives and I've fitted it........... Smile
[Image: 139938.png]
