14-03-12, 03:16 PM
		Hi
I got a 600 99 year model, for about 4 years. I need to change the chain and sprockets.The old chain did not last very long (DID O-ring chain). I changed the front sprocket, put a new nut ( nut and new washer and ). my new chain `t so I mount the rear wheel, because I need to move bike from the middle of my garage, and then noticed that the front and rear sprocket are misalignment like on the diagram, only in my case rear sprocket is moved to the the swing arm!:
Front and rear sprocket are not in line.Rear sprocket escapes to the outside for the entire thickness of front sprocket.I have checked everything on the rear wheel, all the spacers and according to the manual.
I notice that the front sprocket was really eaten on the inside.
Do any of you have checked this, or is it just another factory error? maybe this is somehow connected with the problem of losing of the front sprocket and washer?
When the chain on the engine in it is hard to see but now as clear as day.
Can someone check on this on your .
Thank You
Thank You
