04-03-12, 02:25 PM
Hi!
After bit of advice....whilst riding the other day (pardon me if this is really lame) but i was able to change up gears, without using the clutch??? Is this normal on fazers? I had a 06 ninja prior to my fazer, and was told this was ok to do on a ninja....didnt know if same rules applied...i.e. being a different gearbox etck? I know my clutch cable needs replacing as its at end of its adjustment....and after the bike has been running for half an hour, there is a slight rattle at the clutch (which stops when u pull the lever in).....just after some info/advice/comments/mockery
Cheers!
Cheers!
not a habit i have anyway, just so i know if i did i wouldnt be mashing gear box!
