Spark plugs again
Ok I was going to post on the other thread but it was to long and mostly an argument. One of my plugs (plug 1) is in at a different angle if only slight. It maybe that the thread has been stripped. Now the bike runs as per normal with no blowing around the plug.
Question
Has anyone had to re- thread a plug hole and is it expensive. On the last thread the starter stated a plug had snapped in his! Did you have to re thread or did you get it out. Is there any point in re threading if no blowing and the bike runs like normal. ?
I had a problem recently with plug 4 on mine - all the plugs came out but the new one wouldnt go back in. Ended up taking it to a garage and had a helicoil put in - cost me £50 including them to come out and pick the bike up (was about £30 in actual work) and it was done in 3 or 4 hours Smile
Since plug 1 is on the outside of the engine (like plug 4 according the the labels on mine) then there shouldn't be a huge fuss about having to get the engine out etc and labour costs should be reduced.
Thanks dude.
Having spoken to a mate who does his own work he feels that a helicoil may not be best in an environment that generate this much heat. He feels that it is a good quick fix but he is also a perfectionist with mechanical work. This is not to dis the last post which is mucho appreciated. But there maybe others that won't to throw in there two pence worth.
I'm afraid my technical expertise isn't fantastic - I'm still learning Tongue This is just what happened to mine when I took it to my local mechanics, they only deal with bikes and have been great so far
Did your friend say why a helicoil is a bad idea in a high temperature environment? I'm just curious now Smile
By the way, no offence taken. Its a forum and the whole point is for everyone to contribute their opinions and experiences
As he explained it to me and I'm not technical either
is this. The helicoil is a spring. The cylinder is bored out ( this should be done with the head off in case any bits fall in) with the new thread that is now larger than the spark plug. The coil is now threaded into the hole and the plug placed in. I think maybe he was thinking of expansion/contraction and working loose.
He mentioned another method but I can remember the name. I think in effect you bore the hole out and put a new thread in. This in some way is a more permanent method.
Now that really was not a technical explanation. When I next talk to him I will get the better answer.
Some info, perhaps better than helicoil but still need to remove the head http://www.timesert.co.uk/time-sert.php
Yes just spoke to my mate and that's what he recommends
