What Threadlock?
What threadlock would you recommend or have you used when replacing the front sprocket nut?I don't want to use the ultimate strenght stuff that has to be heated to 300 degrees before you can remove the nut but I want something that will hold the nut tight until I need to replace the front sprocket.Thanks in advance for any replies.
Looks like you need blue thread lock
(28-02-12, 10:47 PM)Oxygen link Wrote: Looks like you need blue thread lock
Not my research
Loctite do two main types of threadlock, Red grade which is semi-permanent (practically superglue - get the impact wrench out!!) and Blue grade (milder threadlock, breakable with a hand wrench).
Apparently the Blue stuff serves a dual purpose, one to protect the threads from corrosion and to prevent vibration and heat/cold from working the bolts loose over time.
Thanks Oxygen.
