20-02-12, 09:56 PM
Is it easy to fit a lowering kit to the 03 fzs600 and also to sculped the seat, i'm only 5'4 and have a short inside leg!! :rolleyes
My and my beloved fazer misbehaving on the roads of life!!!!
Lowering kits
20-02-12, 09:56 PM
20-02-12, 11:10 PM
Changing the linkage is very easy if somebody helps you moving the wheel.
There is a lot of info in the old forum. http://fazerowners.yuku.com/
20-02-12, 11:31 PM
It's a two bolt job and if the bike's on the centre stand, place a plank of wood under the wheel and that'll make it a one man job to raise the wheel when it comes to replacing the 2nd bolt.
Be aware that your bike will steer much slower as the forks are gonna be raked out further. Have you thought about getting a modified seat with padding removed from the sides rather than the top ? That'll make it far easier to get your feet on the ground via your wee legs. Baz ![]()
21-02-12, 12:33 AM
My legs are very much wee and my inside is 29cm, but i dont mind!!!
21-02-12, 12:37 AM
Are hyperpro lowering kits any good for the 03 fzs600??? 8)
23-02-12, 09:18 PM
(21-02-12, 12:33 AM)Tourx4 link Wrote: My legs are very much wee and my inside is 29cm, but i dont mind!!! You mean 29 inches surely :eek ... No lowering kit is gonna be low enough for someone with an 11'' inside leg. Seriously, I don't know about hyperpro kits but I would imagine that most will function in the same way. I'd still adjust the seat though. Baz ![]()
23-02-12, 09:20 PM
@Fazbaz yep i did mean 29 inch inside leg :lol :lol :lol
« Next Oldest | Next Newest »
