throttle shut off
just bought a fazer 6 1999 and the throttle wont shut off as quick as i think it should do after a quick blip , any ideas anyone  :\
throttle cable probably needs re-greasing would be my 1st guess
I had a similar problem recently. After lifting the tank I discovered the nut securing the throttle return cable on the carb bank had become loose and the cable outer had unseated itself, so maybe the same thing's happened to yours.
And, as Bracechenko says, check the cables are lubricated.
thanks guys i will add it to the list of jobs for the weekend  Smile
