firing order
hi all does anyone know the firing order for a 98 fazer600 on the coils from left to right is it 1324? :rolleyes
The coil on the left fires the plugs in No 1 and 4 cylinders at the same time and the coil on the right does No 2 and 3 at the same time. Which cylinder is toward the end of the compression stroke (and thus about to fire) and which is toward the end of the exhaust stroke (and the spark has no effect), is dependant on the valve timing. I should know the order, but I don't. However it will not be 1324. It is either 1243 or 1342.
If you already know most of this please excuse me as I don't wish to be condescending.
I think it is 1243, but not 100% sure.
no not at all thankyou for that only owned the bike 4weeks and its not running very well just thought id ask so i can check at weekend ,its a bit of a brain tester finding the problem :o
