IIRC the AIS has no electrical conection. As you guess it's probably a thermo connection.
		Lift the tank up, you will be able to connect it easily.
		Its for the temp warning light.
Does your fan run if the bike is started & left running for a couple of minutes whilst out of gear ?
		Ooo I have noticed that the fan on mine (-04) does this, is it supposed to do it? Also if I put it in gear the fan goes off, found no mention of these in the manual so is it normal Fazer behaviour??
P
		I was under the impression that the fan cut in after a bit when the bike was in neutral was to protect the fan itself rather than stop the engine overheating.  If it did not cut in, being that close to the rad, could cause the fan and its motor problems.
I doubt* any water is actually moving through the system at tickover to benefit from a cooling fan.
*  Although I actually have no idea what type of water pump is on the Fazer
		not sure why the fan does come on, but in 10 yrs of fazer ownership...it always has come on about  a minute after leaving bike to warm up in neutral...and it goes off as soon as a gear is selected. It aint a fault.
		10-02-12, 10:33 PM
(This post was last modified: 10-02-12, 10:37 PM by chaparral02.)
		 (02-02-12, 04:05 PM)Ghoti link Wrote:  I doubt* any water is actually moving through the system at tickover to benefit from a cooling fan.
Your bike would overheat very quickly if it was left ticking over without a working cooling fan...
The cooling fan is normally used more when the bike is stopped at tickover then any other time
If the is bike not moving then there going be no air being forced through the rad to cool the water..
08 Graphite Grey FZ1 ABS..
Yoshi CF R-77 Full system, FCE, Ivans Flies, PC-V + Autotune Kit, DNA Aifilter & Airbox Mod, Speedo healer ,16T front gen1 sprocket,
Sargent front & rear seats, Fender eliminator, CA Intergated Rear Led, MRA Vario Screen , Givi mono rack & V46 topbox
