20-01-12, 08:01 PM
Right can anyone tell me how to identify a Uk spec from a euro spec headlight unit on the early shape Fzs600. Is the difference only in the reflectors inside or are the bulbs at different sides?
On main beam mine lights up the rh/side of the road as opposed to going off to the left as it should. Run the chassis number through at a Yamaha dealers and apparently it's a Norwegian bike. Bought a headlight unit checked with the seller it's from a uk bike which i was told it is. Looked today and i can't see any different markings from the one in my bike at the moment, the bulbs are the same way around although the right hand bulb on mine says Germany at it's base where the voltage and wattage is printed and the new one says France. The one marking i haven't found is the part number given in the part's catalogue i downloaded from here. Every other component in the headlight has only part number except the whole unit which has number 5DM-84310-00-00 or 5DM-84310-10-00. Help!
