clutch feels wrong
hi to all, read the recent topic started by trisaki found it very interesting, as i have the same problems when my bike is warm but with a couple of extra probs i have a clutch rattle in nuetral until i pull clutch lever in AND when i'm in 1st gear waiting at lights i can feel the bike edging forward rev the bike up and this becomes more prominant, bike has done 36,000 mls changed oil chain at right tension and clutch lever ok anyone got any idea's. cheers breamcatcher Smile
semi synth or fully synth
hi, can you recommend one
(16-01-12, 10:19 PM)breamcatcher link Wrote: i have a clutch rattle in nuetral until i pull clutch lever in
Thats normal they all do that sir...... Unless its REALY loud
I belive most ppl use semi synth, i know i do.
As for the bike wanting to pull forward with the clutch in, my rear wheel will turn slowly if its in gear with clutch in on the centre stand, but it wouldnt be noticable in normal use.
Are you sure the clutch is adjusted right, maybe try adjusting it to the point its slipping slightly and see if it still dose it.
[Image: 82304.png]
stay away from fully synth most makes of modern bikes dont like em buddy's bike had wicked drag on fully synth changed it out drag gone worth a try or as ghostie says adjustment
Have a good look at the clutch cable, the girlfriend's bike (Suzuki gladius)  was doing the same thing and the cable was frayed and split up by the leaver but it was hidden in the outer sheath.
Also take a look at this thread:
http://www.yamahafz1oa.com/forum/showthr...ch+problem
(17-01-12, 06:16 AM)Spud link Wrote: Have a good look at the clutch cable, the girlfriend's bike (Suzuki gladius)  was doing the same thing and the cable was frayed and split up by the leaver but it was hidden in the outer sheath.
been there  :lol
change the clutch  :rollin still did not fix it  :rolleyes
then I spray some wd40 down it and see if that sorts it out  Wink then i found the split  in the cable because i cud see wd40
full licenses don't come in cornflake packets!
(17-01-12, 05:20 AM)devilsyam link Wrote: stay away from fully synth most makes of modern bikes dont like em
Bollocks. Utter.
Motorcycle specific fully synth is OK, on most new and many old(er) bikes.
I believe the problem is clutch cable tension.
Oh, and clutch lever it the one on the LEFT side! Smile
(17-01-12, 11:59 AM)Slaninar link Wrote: [quote author=devilsyam link=topic=1394.msg10014#msg10014 date=1326774050]
Bollocks. Utter.
Exactly. Where do these urban myths come from?
Thanks for all your comments everyone, Smile got a mechanic coming round saturday morn to change the oil and filter again! and check the condition and tension of the clutch cable he recommends motul 5100  10w40 4T any comments. cheers breamcatcher
(17-01-12, 07:42 PM)breamcatcher link Wrote:Thanks for all your comments everyone, Smile got a mechanic coming round saturday morn to change the oil and filter again! and check the condition and tension of the clutch cable he recommends motul 5100  10w40 4T any comments. cheers breamcatcher
Very nice oil. 7100 full synt is also nice, even better (10w40).
(17-01-12, 07:42 PM)breamcatcher link Wrote:motul 5100  10w40 4T any comments. cheers breamcatcher
always used it. Get it off ebay with a filter for £33ish i think (5 litre can i think?)
cheers everyone let you know the outcome Smile
(17-01-12, 11:34 AM)bikerboys link Wrote:[quote author=Spud link=topic=1394.msg10015#msg10015 date=1326777384]
been there  :lol
:rollin I did the same thing so now have a spare clutch for a suzi 650.
