E-mailed him with a link to this topic. Will see what he says.
Here are dimensions (my sloppy MS paint drawing, sorry):
The other side is the same, that's written in Serbian.
NOw, the frontal part of the grill is 405 mm wide and 175 mm high, with sides (radiator thickness) 50 mm.
So you need aluminium plate of 500 x 170 or 175 mm dimensions.
Holes are drilled around 38 (40) mm from the top, the next one 100 mm lower. Both some 25 mm from the edge.
This is not very nice, most explaining was done over the phone and the man made a nice technical drawing for the workshop to work on it. He also made the übercool design.
Here is what it looks like before it is bent under 90 degrees at the sides (these are for Yamaha TDM and a Suzuki SV):
Sorry for bad English and worse paind drawing, hope this helps you at least a bit. Hope Dimac will send his drawing and design (for free
Cheers
