Throttle Position Sensor test. Please Help!!!!
Ive just fitted some heated grips to my bike,(1999 FZS600) gone up the road everything fine, then all of a sudden ive got a missfire on cyl no4. I switched it off, then disconnected the TPS and put the ignition on, and I get a reading of 3000rpm every couple of seconds, then back to zero then 3000 again. Any ideas what that code means?  :'(
[Image: 139938.png]
your fault is the TPS
All sorted, had crap in no4 float bowl, drained it out alls well! I think the TPS was me not doing the test properly, ie disconnectiing it before turning ign on as opposed to turning ign on then disconnecting it!
Thanks anyway  Wink
[Image: 139938.png]
(09-01-12, 08:09 AM)Fazerjon link Wrote: All sorted, had crap in no4 float bowl, drained it out alls well! I think the TPS was me not doing the test properly, ie disconnectiing it before turning ign on as opposed to turning ign on then disconnecting it!
Thanks anyway  Wink
Sounds like it glad it's all sorted now.
Later
Yep, you cant beat crap in the float bowl! :lol
[Image: 139938.png]
