08-01-12, 01:14 AM
		Going out for a ride yesterday on my FZ6 '04, it tried to crank the engine once, sluggishly, then I got the dreaded "buzz" of the solenoid indicating a flat battery
(Probably I should have put it on charge when I got back from my mother's after Xmas, but anyway...)
I managed to bump start it, rode fine and when I got back, got the Optimate III out to charge the battery up.
The problem is that, after plugging it in, I got the Green "power" light, but none of the others until after a few minutes the "desulphate" light came on which I thought only comes on if the battery is near dead.
As it was dark I couldn't do anything about it then (no light in the shed) and today I was out for another Observed ride, so I just hoped it would start today, which it did.
It was ok until we did some slow riding practice and at one point I thoughtlessly sat on it with the engine off, but the headlight still on, meaning that when I tried to start it... buzz....
So I bump start it again, ride ok, and at the next two stops, switch off promptly, restart, no problem.
I get home and again try to plug in the Optimate, but still get only the Power light.
I have the Optimate adapter (bolts to the battery and has a covered connector to go to the charger) and the contacts appear to be clean and seem to fit together ok, so I'm not sure what's going on. Is the Optimate buggered? Is the battery shot (but if it was, surely it wouldn't start at all)?
Anyone got any ideas?
