Looking for a bike sat nav for a trip to Europe in June. I can see that they're £200+ new but will be keeping an eye out on Fleabay for 2nd's.
Anyone got any recommendations for models/brands etc? Are they all battery or do they generally hook up to the bike? I've not got a 12v socket and don't really want to fit one if I can help it but if the sat nav can hook straight to the battery then happy days.
Ta
Brace
		Being a cheapskate I use an old car satnav on the bike. I have a 12v socket under the seat so that a satnav can run from that with an extension wire to the handlebars. Can also be used to charge your phone etc.
		Yeah think i'll keep floating about Ebay on the prowl for a bargain.
Will deffo take maps anyway as a backup too :thumbup
		I use tomtom iphone app.  Mouth phone in waterproof case on bars and hook up to 12V under seat, or you could go straight to battery.  This is a cheap option only if you already have an iphone
		Garmin - great kit!  I have the Zumo 550 and wouldn't go touring without it.
		I was given a Garmin for my car last year. only used it once but it seems good n haven't heard bad reports from Garmin kit. :rolleyes
		garmin zumo 660 if you can afford it. prices dropping below £400 at the mo.
comes with a car kit as well as all you need to fit to the bike. I've wired mine straight to the battery. if you have an intercom (eg autocom) you can hear the distractions, I mean instructions; you can connect your phone by bluetooth; the unit takes a 16gb microsd card which you can fill with music.
other garmin zumos are available too - IIRC 220 new, 500 & 550 second hand.
		I  use a very cheepo navigo 3.5 I have fitted TT 7.9 europe  I bought a standard motor bike mount clamp and a home made charger ,Walkman headpones for sound.This is permanently connected to the battery and a loose lead, cable tied around the steering head. Used this set up quite a lot over the last 3 years , Overhead sun can be a problem ,but apart from that great !
		 This is how I mounted a cheap car type sat nav to my Mk1 FZS600 with a simple home made bracket from the mirror mounting studs. Although I do have the Mk2 mirrors on with slightly longer studs.
[smg id=390]
[smg id=391]
 I can't hear the sound but I tend only to use it for navigating minor roads in unfamiliar places, where a quick glance saves having to stop and check out the map. The fairing shields it from light rain, but if it is really wet I stick it in the tank bag out of the way.
I'm not recommending this particular sat nav, which I got from Aldi, as although it has major roads of Europe in it, on a trip into Europe I found it sadly lacking.
		I have a tomtom rider v1 and it's awesome - has withstood being thrown down the road once (oops) and is waterproof etc
Bit of a brick though!
		Garmin sometimes have reconditioned units for sale but you have to ring them to find out.
I traded in my 550 which was quite battered for a recon 600 series with lots of extra bits that I never had for the older unit (car mount, adaptor etc) for £111, I had to send them the unit only (so sold the other bits I had on ebay to get some money back) and they sent me the spangly newer one with all the extra kit. The units they take in in p ex such as my 550 get reconditioned and put back for sale.
		Garmin Zumo 220.........waterproof as it's bike dedicated.
Had mine wired direct from battery which was fine when touring daily, but when bike was laid up for a couple of weeks I found it was draining the battery even with the sat nav removed from the bike.
Now I've had it wired in to a switched circuit (not by me I'm pleased to say as I probably would have caused electrical meltdown  :eek ), everything is fine.
A word of warning; when I got the wiring done the guys had to find a circuit which wasn't related to the ABS system (Gen 2 FZ1S Fazer abs).
I can only assume it could affect the ABS system if you splice in other kit ???
Now coupled with an Interphone headset so I can hear the instructions too, very handy piece of kit.
		Lots of ideas so thanks everyone. Basically going to decide this week whether we go cheap and cheerful or pay out a little bit more. Will speak to my buddies who are coming along and decide then.
Cheers for the heads up Lonewolf, mine is a gen 2 FZ1-S with ABS :thumbup
