29-10-11, 04:46 PM
Considering i don't use my bike for commuting only a nice ride out now and then what would you recommend as the best Value against performance Pads i should fit.
My discs are ok within Haynes Manual Tolerance as measured with a Caliper.
I will replace the Brake Fluid as i don't know when it was last done and may replace the Seals if they look poor.
Do i really need new Brake lines or should the what look like originals be ok, is there a big improvement or is it just for looks?
