22-10-11, 04:51 PM
Hi, has anyone any recommendations for a good battery charger? Been meaning to get one for ages but there are so many out there it's a minefield. No doubt some are good and some are crap. Thanks, David.
Battery Chargers
22-10-11, 04:51 PM
22-10-11, 06:38 PM
get a optimate http://www.accumate.co.uk/it010003.html
22-10-11, 10:42 PM
Depends how "techy" you want to get and how cheap you want to be.
Optimate is good if you've got £50-£80 to spare and you want no hassle - just leave it connected. I use a Lidl 500mA battery conditioner thing that cost £5. - I have it on a timer (1 hour a day) It tops the battery up to 13.5V and then stops charging. For most purposes its as good as an optimate. I used to use a standard car battery charger with a 10 ohm series resistor and monitored it with a voltmeter (that cost £0.00) Avoid: - A car battery charger directly connected to the battery. - Any charger or "trickle charger" for "small batteries" that doesn't self-limit at 13.5V (There are plenty out there ) - All solar battery chargers unless you KNOW that they cut off at 13.5V (There is a lot of bollox talked about solar battery chargers - the phrase "current limited" is meaningless) (Come to think of it ... there's a lot of bollox talked about battery chargers generally) (But then ... there's a lot of bollox talked generally :rollin )
23-10-11, 09:55 PM
I recently got a Dr Bike battery conditioner which cost me around £25 sorry,I cant remember where it came from but I think I got it via Amazon, google it anyway It works fine as you can leave the battery connected and it will top up as its a proper conditioner not a trickle charger which I nearly bought as unlike the good Major Im crap with electrics, for instance I used to connect my Speed triple's battery to a car charger like a pillock which soon saw it off !
« Next Oldest | Next Newest »
