2002 engine in 1998
I'm pretty sure the answer is yes but will the 2002 engine fit into the 1998 chassis and the generator and starter motor fit etc?
yep spot on mate Wink
great stuff. I'll order it then. Not a good morning.
[Image: outofbed007.jpg]
OUCH!!
have bought some liquid metal and araldite for the rod. The back of the cases are smashed too. Oops.
how what did you hurt yourself  :eek
Very nasty. Did any debris get into the gearbox?
(I'm always paranoid about something locking it when any of the reciprocating bits let go in a big way.)
Great picture presentation but sad looking engine  :'( .
I may be wrong on this but I seem to remember that after 2001 the generator has a slightly higher output and a different plug on the end of the wires. The higher output is no problem but some slight modification to the wire connection point may be required.
(21-10-11, 07:42 PM)limax2 link Wrote:Great picture presentation but sad looking engine  :'( .
2002 models on have a different alternator
:'( Did the crank let go?
I have a couple of 600 FZS engines on the shelf, I normally do them for £250 with £50 back if you exchange the old engine.
Let me know if you are interested
Mark 07887 854614
Motorcycle Republic
Fat Maggot Clothing Company - remember FOCU15 to claim your foccers discount
(21-10-11, 10:22 PM)oldmotherfoccer link Wrote:I have a couple of 600 FZS engines on the shelf, I normally do them for £250 with £50 back if you exchange the old engine.
Mark 07887 854614
Motorcycle Republic
damn, sorry, just ordered a 2002 25k miler from Swindon before I saw this.
You can have the old engine if you like but I don't think there will be much useful on it. The valves, crankcases, crank and one of the rods / pistons are fubarred.
[Image: 111021OopsFazer011a.jpg][Image: 111021OopsFazer003a.jpg]
So any idea as to what actually happened? first time ive seen an engine with that amount of damage!
Havent seen this much damage to a faz engine since a certain foccer was attempting to perfect the art of turbo charging his bike.
(22-10-11, 06:12 PM)Deefer666 link Wrote:Havent seen this much damage to a faz engine since a certain foccer was attempting to perfect the art of turbo charging his bike.
Yep same here too snap a rod like that takes huge force!
Later
Hmmmmm, well, no. It just went as I was accelerating down the slip road to join the M27, it felt like a misfire but with considerably more mechanical noise.  Smile
No warning, just let go, engine never over revved although had 80 000 miles on her. Other 3 still sounded sweet  :lol
Rather smokey too for the time she was running until the bottom part of the rod securely locked itself into the hole in the front case.
(24-10-11, 08:34 AM)Lumpy link Wrote:Hmmmmm, well, no. It just went as I was accelerating down the slip road to join the M27, it felt like a misfire but with considerably more mechanical noise.  Smile
Have you had it from new/low mileage, how long/mileage have you had it for?
Later
(24-10-11, 08:55 AM)Gnasher link Wrote:Have you had it from new/low mileage, how long/mileage have you had it for?
OH NO, I bought it a bit sheddy at about 55 000 miles and I have put 25 000 on her. Amazing machine and saves wear and tear on the others in the crap weather. Always good oil, never over revved, etc. although used to the full. Engineering wise, when it's time to break it breaks whenever that may be although at 80k is a little early. At 7-8000 revs, the rod half flailing around will cause a lot of damage in no time as it didn't seize straight away. Had it seized straight away the apparent damage may well have been less.
