1999 fazer 600 forks
Hi all, quick question, does anyone know if the forks from a 2002 fazer would fit my 1999 fazer?
Cheers Iain
Yes, and  better too 'cos they'll have the preload adjusters the 98/99 bikes lacked
Cheers mate, thanks  Big Grin
can you just put preload adjusters on any 41mm tube????
(02-04-18, 02:52 PM)psyfi_1 link Wrote: can you just put preload adjusters on any 41mm tube????
the springs are different lengths so not really
FZS models
1998 and 1999 models
Standard 323 mm
Service limit 319 mm
2000 models
Standard 316.8 mm
Service limit 309.8 mm
and probably a different spring coil pattern or whatever you would call it
Cut 11mm off the spacer tubes and away you go
(02-04-18, 07:32 PM)unfazed link Wrote: Cut 11mm off the spacer tubes and away you go
not sure if i would want to be the one to test that theory
but if you have some spare spacers then its worth a shot
I did  Big Grin on the fazer400. thats the length or the lower section of the adjusters
