downpipe nuts
i think im going to have problems removing these nuts,they are in a bad way,are the studs prone to break?
[Image: IMG_0385.jpg]
mine weren't as bad as yours, granted, but they all came undone ok which surprised me as they didn't look as though they would.
i pre-warned my mechanic friend that i was going to be putting a socket
on them and asked about if it went wrong would i be in for a whole load of trouble? - he replied that it was not a problem if studs sheared.
i did liberally apply penetrating oil the day before, don't know how much difference it made.
good luck!
are you going to be cleaning / painting the front of the engine while the exhaust is off?
is it clean enough?
I have seen worse.
I think the studs are pretty good and although the nuts maybe screwed up i bet the come out if care is taken.
pre treat with a REAL penertraiting oil for as long as you can... weeks if possable lol
but due to the angles of the studs i doubt it will have a huge effect. but every little helps.
[Image: 82304.png]
i will give it a clean up when the pipes are off and a lick of paint,i have aqquired an exup asm off ebay but as this will take a few weeks to come (from the states) i will leave the downpipes on for a bit longer and give them a bit more soaking with penetrating fluid
I took the rad off of one of mine that was almost the same as yours!
I wire brushed the excess rust off the nuts first & used 'DUCK OIL' which is an inexpensive penetrating oil that I have been using over 20 years now.
Female 'TORX' sockets are what I used to get a couple off as they were that corroded I could not get a standard metric sized 3/8's drive socket on them, but as has been said before ALL of them came off & the threads were fine.
P.S dont forget to clean the ports up with a small drill with a brush on as if it's not perfectly clean you will get a blow from the front pipes! (I learned the hard way :  /  )
as i have to buy new nuts i am looking at stainless steel nuts on ebay,i have found some dome nuts,i was thinking that they will stop the studs from rusting,do you think they will look ok?
they will look the nuts! for sure.
they will have to be long enough to tighten the collars sufficiently before doming out as it were. they don't have a high torque rating (surprisingly and thankfully) only 15lbft.
what's the link? it's a brilliant idea that i'd like to copy blatently if you don't mind.
is it clean enough?
I changed mine for stainless dome nuts , got them from STAGONSET , they have a vast array of stainless fasteners , cheap and fast delivery . to ensure nuts didnt bottom out on tightening i used two stainless washers under each nut . hope this helps Smile
they look loads better than the OE one's and protect the stus threads
(12-10-11, 09:18 AM)bludclot link Wrote:they will look the nuts! for sure.
here is the link on ebay for 10 nuts http://www.ebay.co.uk/itm/370170347721?s...1438.l2649
Dont forget to put plenty of 'HIGH TEMP' anti seize paste/grease (not copper slip) on them or they will just seize up again!
(12-10-11, 05:57 PM)chitsu link Wrote:Dont forget to put plenty of 'HIGH TEMP' anti seize paste/grease (not copper slip) on them or they will just seize up again!
Hi, I always thought Coppaslip WAS high temp grease. What is the difference, and what High temp paste do you use?
(12-10-11, 08:46 PM)nettshubby link Wrote:[quote author=chitsu link=topic=477.msg2858#msg2858 date=1318438667]
[/quote]Copaslip®Copaslip® (often misspelled as copperslip or coppaslip) - the original anti-seize compound. It is a very high temperature (up to 1100°C) anti-seize assembly compound, bentone based non-melt grease with copper, polybutene, and anti-corrosion additives.
i have bought some coma copper ease,it has a temperature range of -40 to +1150 degrees c so should be ideal for the exup valve,i have also bought some shock and unlock spray,it is suposed to be good for removing corroded nuts
